    Recaolbox does not start
    recaolbox does start
    • BlackCrow666
      BlackCrow666 last edited by
      I installed Recalbox on an NVMe SSD (USB enclosure); after the blue screen to launch the OS, the screen remains black. I left the PC on for more than an hour, but nothing happened...
      I restarted and checked on Windows if it had actually created the system partitions, and it has. I can't explain why it won't boot though...
      My PC configuration is as follows:
      Ryzen 5 3600x
      RTX 4060
      B450 Aorus Pro
      16GB 3600MHz
      BlackCrow666 1 Reply Last reply Reply Quote 0
      • BlackCrow666
        BlackCrow666 @BlackCrow666 last edited by
        in the recalbox.log file says:
        [ 7.76] [nvidia-install] [INFO] Trying to install Nvidia controller 10de:2882
        [ 7.76] [nvidia-install] [ERROR] GPU error(0x2882): Controller not supported. Is GPU?
        [ 7.76] [nvidia-install] [INFO] Trying to install Nvidia controller 10de:22be
        [ 7.77] [nvidia-install] [ERROR] GPU error(0x22be): Controller not supported. Is GPU?
        [ 7.81] [nvidia-install] [INFO] Trying to install Nvidia controller 10de:2882
        [ 7.82] [nvidia-install] [ERROR] GPU error(0x2882): Controller not supported. Is GPU?
        [ 7.82] [nvidia-install] [INFO] Trying to install Nvidia controller 10de:22be
        [ 7.82] [nvidia-install] [ERROR] GPU error(0x22be): Controller not supported. Is GPU?
        [ 9.70] [S06splash] [INSTALL] Install in progress. Don't play boot video
        • Magaki
          Magaki last edited by
          Seems your RTX 4060 is not supported for Recalbox...
          • BlackCrow666
            BlackCrow666 @Magaki last edited by
            @Magaki said in Recaolbox does not start:
            True, I had to switch to another OS 😅
