    Solved Can't pair bluetooth MadCatz C.T.R.L.R
    GamePad/GPIO/USB encoder
    cant pair bluetooth madcatz c.t.r.l.r
    18403
      @elchhome sorry dude, I was out for the weekend. Gonna check your file today and report back.
        @elchhome try those commands through SSH :
        mount -o remount, rw /
        echo 'SUBSYSTEM=="input", ATTRS{name}=="Mad Catz C.T.R.L.R", MODE="0666", ENV{ID_INPUT_JOYSTICK}="1"' >> /etc/udev/rules.d/99-joysticks-exotics.rules
        reboot && logout
        Your pad is, as I expected, considered as a mouse/keyboard. Those commands above will force the joystick bit, and it should then work. Can you confirm ? If yes, we'll add your pad to 4.1 so that it's automatically detected as a pad
        • elchhome
          elchhome last edited by elchhome
          @subs
          Thanks a lot! This change makes the controller available to the system.
          Good work! 🙂
            @acris a reminder for you to include the udev rule in 4.1
              @subs it s done
              https://github.com/recalbox/recalbox-buildroot/pull/461/commits/a00f6c3a6c226a2bcd54044fd0e477c10c61e2e0
                @acris Nice !
                • wden86
                  wden86 last edited by
                  Hi all,
                  I just got a raspberry pi3, installed recalbox 4.0 on it and tried to set up my gamepads.
                  No trouble with 8bitDo NES pro, nor with an USB generic gamepad.
                  I tried to set up my Mad Catz C.T.R.L.R with this topic's solution.
                  Adding a line in the joystick rule file didn't work at first because of device name.
                  Indeed, the sdptool command on the MAC address told me the device's name is not "Mad Catz C.T.R.L.R", but "HID Gamepad".
                  The CTRLR switch is set on the gamepad.
                  Regars,
                  Denis
                  100.6k
