    How does the Hotkey(s) work?
    does hotkeys
    • valvolt
      valvolt last edited by
      I've found that you can execute special commands through hotkey inputs, as per the following link.
      Where are these configured, can the special commands be bound to other commands ?
      Specifically, I'd like to know if I could bind commands (for example Hotkey + L) to increase or decrease the sound volume (at least in Retroarch) instead of rewinding the game, and how ?
      Thanks for your answer 🙂
      RPi3 & XArcade Tankstick running inside the Street Fighter cabinet - Now SECURE YOUR BOX!
      • DAM
        DAM last edited by
        there are more buttons available for it, see:
        https://github.com/recalbox/recalbox-os/issues/700
        Only if there is a way to change the standard shortcuts, but that I believe only in the next version.
        • valvolt
          I added a comment to the issue, thanks for the pointer !
          So I guess there is no config file mapping buttons to features I assume?
