    Solved Accessing the saves folder (reload)
    accessing saves reload
    • TheIronyste
      TheIronyste last edited by
      Hey,
      (I searched and read topics I found but still can't access save folder)
      I hope someone can help me. I'm really new in Recalbox world and have a problem concerning the access to the save folder. (I'm not a programer or Linux user 😉 )
      When I go to //recalbox/ I get the Recalbox menu, I can drag and drop roms but can't have access to the save files. (same with the IP, which seems normal...)
      When I try to acces the recalbox files in my explorer, I can't find it (only my internet box, and shared printer).
      Without that file, I can't put my saves in my recalbox.
      Thanks for your help!
      • DjLeChuck
        DjLeChuck last edited by
        Hi,
        You can access it throught your network.
        In the windows explorer, if you type //recalbox/ you are redirected to the web interface, but if you type \recalbox\ you should see a /share folder with all the systems, etc. and the saves folder.
          Hi !
          Saves are not available through the manager. Rather point your explorer to \\recalbox\share\saves and you svould find them. No http
          • TheIronyste
            TheIronyste last edited by TheIronyste
            Hi again,
            Thanks for your answers 🙂
            file://recalbox/share/saves/ works fine.
            Thank YOU!
            Thanks!
            • DjLeChuck
              Your welcome!
              Don't forget to mark the topic as resolved. 😉
