    Start CRT in 50Hz mode (PAL)
    start crt 50hz mode pal
    • flip79
      flip79 last edited by
      Hi all 😊
      I have a Raspberry PI 4 with PI2SCART, it works flawlessly with Recalbox 👍
      Now I want to use it with a TV that doesn't support 60 Hz at all: I can't browse the menus because Emulationstation (and the boot screen) starts in 240p @60 Hz. I tried everything to force it to 50 Hz, but I can't find a way to do it. Could you help me?
      Thank you in advance!
      flip79 1 Reply Last reply Reply Quote 0
      • flip79
        flip79 @flip79 last edited by
        Finally, I modified the recalboxrgbdual.ko driver by forcing 50 Hz. Since I have a Pi2Scart which, unlike the RGB Dual, doesn’t have a 50Hz/60Hz switch, I altered the C source code so that it always runs at 50 Hz, as if I had an RGB Dual set to 50 Hz, then I recompiled it for the version I'm using (Recalbox 9.2.2-pulsar).
        It works! Of course, I have to use only PAL ROMs; otherwise, Recalbox will (rightly) switch to 60 Hz mode.
