    IPAC2 player 2 bug still present?
    GamePad/GPIO/USB encoder
    ipac2 player still present
    • jeroenvdd
      jeroenvdd last edited by
      Dear all,
      firstly my setup:
      laptop running latest Recalbox build (download 23/12/2024)
      arcade cabinet with setup:
      1 4-axis joystick per player
      6 buttons per player
      4 'menu' buttons on the cabinet
      1 insert coin button
      1 p1 and 1 p2 button
      I've got an Ipac2 (post 2015) on the latest firmware.
      when I hook it up (d-input selected) recalbox recognised 2 controllers,
      (this is the good part 🙂 )
      firstly i go to configure and press a button on my left p1 side of the arcarde: works perfectly I can go trough the settings and map every button as intended.
      now for the bad part: Player 2
      again i go to configure controller -> it asks me to push a button:
      • i push a button on P2 side -> nothing happens, I try another and the setup menu opens as intended.
      at this point fe my joysticks cant be mapped to the dpad or other stuff.
      but: when I push a button i want to map I see the 2nd controller icon blinking in the top left corner
      it looks like it already has some config for this controller but i cant seem to overwrite / edit this.
      (I've already done a factory reset of Recalbox = same result)
      does anyone have an idea which steps i can take to resolve this issue?
      100.9k
