    Recalbox PiBoy XRS
    Emulator Arcade/PC/Console
    recalbox piboy xrs
    3525
    • thomasfou
      thomasfou last edited by thomasfou
      Hello,
      I play on my piBoy XRS with Recalbox since 1 year. Don't remember how I do that but it was very simple. I had just one problem sometime the piboy need to be force-stoped when I forgot it one entire night on battery.
      So last month I decide to make a fresh install for Christmas and the kids. Bad Idea ! fresh new card install with recall box image from PI Imager (img described for...DMG) doesn' t start on the piBoy XRS : screen on but steel black, no display Experimental PI logo of the firmware boot....
      Directly plug on a hdmi screen, the same pi and the same sd card (img recalbox ...DMG...) start well recalbox.
      I upgrade the Experimental PI firmware to 1.0.7 (with the exe from Experimental Pi find on archive.org), cause I read it can be a pb of a boot flag : same issue.
      I have other new batteries in my bags, I load them and plug in the piBoy XRS : same issue.
      With a retropie image "modify" with the Experimental PI exe that "upgrade the boot section with firmware 1.0.7, retropie run on this piBoy xrs (same reinstalled sd card).
      It seems that there is no launch of the firmware boot with the recalbox image...
      I can fix this little pb, I want back my recalbox on my piBoy XRS, never use retropie that I doesn't like.
      Please help me .
      • Magaki
        Magaki last edited by
        Hello,
        We don't possess anymore a Piboy XRS on the staff for trying to work for his compatibility for latest version of Recalbox. So we don't support them.
        BUT, if you can find at least a 8.0 (until 9.1) Recalbox image for PI4, it could work for your Piboy XRS.
        Unfortunately, we don't provide old versions of Recalbox, they are not available on official channels.
        thomasfou 1 Reply Last reply Reply Quote 0
        • thomasfou
          thomasfou @Magaki last edited by thomasfou
          @Magaki thanks a lot for your message. I try that in a few days and I give you the result.
          Please can you point a specific name or version of a recalbox 8 image for xrs integration.
          • JAcob
            JAcob last edited by
            "Sounds like a frustrating issue! It seems like the Recalbox image may not be properly compatible with the boot process on your PiBoy XRS. Since the system works with Retropie, it could be a bootloader or firmware compatibility problem specific to Recalbox. I’d recommend trying to reflash the Recalbox image, ensuring you’re using the correct version for the PiBoy XRS, and checking the boot configuration. If the issue persists, reaching out to the Recalbox or PiBoy XRS communities might help get more specific guidance."
            • thomasfou
              thomasfou @JAcob last edited by
              @JAcob Thank you for your answer. Yes it seems to be a compatibility pb between recalbox image and the piBoy XRS. I was able to read that Retropie has a different boot mode that override the firmware boot of the XRS and that could be upgrade with the exe tool of Experimental Pi and it works.
              I have to try with older recalbox images that were able to works well with the XRS.
              but I have a doubt that my issue can be fix cause I have try with an recalbox image found in the archive of the Experimental PI and it failed.
              I come back with more info in few days. Thanks a lot.
              • thomasfou
                Hello, I try a 9.1 image and it works well ! (I think it's the image I have used last year for my XRS config)
                Thanks a lot for your help and the help of the other members of the forum.
                I wish you the best jump into the next year.
                And I hope you can add again the XRS support in the futur Recalbox version, despite the fact that Experimental PI stop the piBoy XRS manufacturing...
                cause I like the diy, the singleboard cp, the simple hack, the reusable work and with Recalbox you have the best way for simple integrated qualitative solution ...and the piBoy is a fantastic case for 80's guy like me)
                Thomas.
                • thomasfou
                  Hello Folks !
                  Today I try to update the piboy XRS from the 9.1 to the 9.2.3 in the recalbox menu on my piBoy XRS, just in case.
                  and I WORKS in 9.2.3 !
                  Hurry up !
                  In the "Advanced settings" menu, I can read again "PIBOY XRS (AUTO)" in the CASE MANAGEMENT field, a pleasure : )
                  The upgrade doesn't beark the piBoy XRS board integration from the 9.1 image of recalbox (the last version of images working with fresh installation).
                  That's a great workaround for XRS new installation.
                  Have an happy new year !
                  Thomas.
                  • genesis8bit
                    genesis8bit last edited by
                    Hi,
                    Where did you download this version 9.1 ?
                    I would like to do the same thing.
                    Thanks.
                    kl4rx 1 Reply Last reply Reply Quote 0
                    • kl4rx
                      kl4rx @genesis8bit last edited by
                      @genesis8bit Hi, you can found the 9.1 for the XRS on archive.org at this url:
                      https://archive.org/details/recalbox-rpi4_64_xrs9.1.img
                      I have faced the same problem, wonderedwhy my XRS wouldn't boot on the 9.2.3 PULSTAR ...
                      The version 9.1 was working fine and then i updated to 9.2.3 PULSTAR with no problems.
