    Recalbox 9.2.3 can't change resolution (slow on 4K tv )
    recalbox 9.2.3 cant slow
    • adam0509
      adam0509 last edited by
      Hi,
      Recalbox is laggy on a 4k tv, even the SNES and NES
      I try to change the resolution, normally here there is a resolution option (under Recalbox CRT)... why it's not here ??
      • adam0509
        is it the only way to modify recalbox.conf now ?
        https://wiki.recalbox.com/en/tutorials/video/display-configuration/complete-video-configuration-guide
        FredMGarcia 1 Reply Last reply Reply Quote 0
        • FredMGarcia
          FredMGarcia @adam0509 last edited by
          @adam0509 said in Recalbox 9.2.3 can't change resolution (slow on 4K tv ):
          Yes, I tried it and it worked, and here's how you can modify recalbox.conf
          • FredMGarcia
            FredMGarcia @FredMGarcia last edited by FredMGarcia
            @FredMGarcia said in Recalbox 9.2.3 can't change resolution (slow on 4K tv ):
            https://wiki.recalbox.com/en/tutorials/video/display-configuration/complete-video-configuration-guide gunspin
            You should try them now because I have done them successfully.
