    How to set-up per core specific settings?
    Emulator Arcade/PC/Console
    11357
    • Luciano Silva
      Luciano Silva last edited by
      I want to set-up one diferent overlay per core.
      I´ve changed this line on "emulatorlauncher.sh"
      if [[ "$emulator" == "atari2600" ]]; then
      /recalbox/scripts/runcommand.sh 4 "$retroarchbin -L $retroarchcores/stella_libretro.so --config /recalbox/share/system/.config/retroarch/config/stella_libretro.cfg "$1""
      fi
      To load my custom settings on the file "stella_libretro.cfg" but retroarch still always loading the default "retroarchcustom.cfg" located at "/recalbox/share/system/configs/retroarch/"
      Someone can explain me how to set-up custom specific per-core settings?
        We don't use emulatorlauncher.sh anymore
        You should read the wiki : https://github.com/recalbox/recalbox-os/wiki/How-to-use-custom-config-for-emulators-(EN)
        • Luciano Silva
          OK , now is working.Thanks.
          But i have a new problem.
          I saw this awesome tutorial:
          https://forum.recalbox.com/topic/1490/vectrex/76
          Adding this line on emulatorlauncher.sh
          "/recalbox/scripts/runcommand.sh 4 "$retroarchbin -L $retroarchcores/vecx_libretro.so --config /recalbox/configs/retroarch/vectrex.cfg --appendconfig /recalbox/share/overlays/vectrex/$filenameNoExt.cfg "$1""
          It`s posible to add a specific overlay for each vectrex game.
          How can i do this with the new setup of recalbox?
            as i said, emulatorlauncher.sh is not used anymore
            Vectrex overlays are a little more complicated to use and need some tweaking in some other files. It should be done in recalbox 4.1
            • Luciano Silva
              Well ill be waiting for next version. Whats the latest version using emulatorlauncher.sh?
                You can change the way vectrex is launched to use ematorlauncher.sh instead. But take care :the file.woild be erased on update
                • Luciano Silva
                  sorry for another replay , could you say me how i do that?
                    You have to mount -o rmount, rw /then edit /recalbox/share_init/system/.emulationstation/es_systems.cfg. There you will see all emulators are launched with a python script. Find the path to emulatorlauncher.sh, and replace the command line to launch vectrex
                    • Luciano Silva
                      Luciano Silva last edited by Luciano Silva
                      Well i`ve used my old rpi1 emulationstation config to launch vectrex but is not working
                      <command>/recalbox/scripts/runcommand.sh 4 "/usr/bin/retroarch -L /usr/lib/libretro/vecx_libretro.so --config /recalbox/share/system/.config/retroarch/config/vecx_libretro.cfg %ROM%"</command>
                      Is the syntaxis correct or the problem is the "vecx_libretro.cfg" file?
                      I´ve tried to launch a game from the shell and its not loading the core , but it seams to load the config file
                      Any suggestion?Thanks for your help
                        i need an output of something to tell you what's wrong. Does /recalbox/scripts/runcommand.sh exists at least ?
                        • Luciano Silva
                          Finally its working , thank you for your help.
                          I share my config:
                          <command>/recalbox/scripts/emulatorlauncher.sh %ROM% "vectrex"</command>
                          if [[ "$emulator" == "vectrex" ]]; then
                          /recalbox/scripts/runcommand.sh 4 "$retroarchbin -L $retroarchcores/vecx_libretro.so --config /recalbox/share/system/.config/retroarch/config/vecx_libretro.cfg --appendconfig /recalbox/share/overlays/vectrex/$filenameNoExt.cfg "$1""
                          fi
                            remember to save the files you changed, they will most probably overwritten on update
