    Trouble with mayflash n64 contoller adapter
    trouble mayflash contoller adapter
    • jslice
      jslice last edited by
      When I have the n64 controller plugged in via mayflash adapter, the controller works and can navigate the menu. The second I try to play any n64 game though, it exits back out to the ES menu. I can play games with other controllers, just not with the mayflash adapter and n64 controller. I also am not sure why when i try to configure the controller, there are no options for the c buttons. I spent a whole day trying to figure this out with zero luck, any advice would be greatly appreciated as I'm a total beginner with raspberry pi's and recal box.
      • Nachtgarm
        Nachtgarm last edited by
        @jslice
        Moved to the correct category and regarding your problem. Try this
        Edit the recalbox.conf to this
        controllers.ps3.enabled=0 and controllers.xboxdrv.enabled=1
        controllers.ps3.enabled=1
        ## Choose an driver between official, shanwan and gasia if you have dualshock clones (official,shanwan,gasia)
        controllers.xboxdrv.enabled=0
          The N64 pad is .. a pain. As it looks like no other controller, mapping a regular pad (i.e. xbox or PS3 layout) is a complicated task. To make it simple : the c pad it the right stick as well as 2 buttons.
          Now, for your particular case, you can lanually edit the mupen configuration files and add n64.configfile=dummy to prevent recalbox from configuring N64 on the fly at each rom launch. Look around the forum, i have answered a few subjects concerning N64 custom config lately
          • jslice
            I'll try this today, thank you so much!!
            • xdsta
              xdsta last edited by xdsta
              Hey,
              there is little bug in the current version. You will have to override the automatic config OR you will have to configure at least this buttons on your controller (maybe the buttons do not exist, but you must set them, don't skip them in the config dialog):
              • "start"
              • "y"
              • "x"
              • "pageup"
              • "up"
              • "right"
              It is the mupenConfig.py that fails, if you missed one button. It takes you back to ES frontend then...
              Greetings,
              Dominik
