    Model3 config file issue ?
    Emulator Arcade/PC/Console
    tion
    • AxelR
      AxelR last edited by
      Hello Recalbox team. Thanks again for this amazing box.
      I think there is a mismatch in the way ConfigGen analyses the Model 3 configuration file ConfigModel3.ini
      Typically, the supermodelGenerator.py script is looking for a key that does not exist in the config file: multi-threading
      Hope this helps...
      AxelR 1 Reply Last reply Reply Quote 0
      • AxelR
        AxelR @AxelR last edited by
        Answering my own question:
        According to the source files on gitlab, it seems the ConfigModel3.ini config file format changed, and now has a new set of entries, that matches what configgen expects.
        https://gitlab.com/recalbox/recalbox/-/blob/master/board/recalbox/fsoverlay/recalbox/share_init/system/configs/model3/ConfigModel3.ini
        I am not sure if it's a bug or if it's related to the recalbox upgrade process which does not erase older config files ?
        • AxelR
          Also, I think there is a typo in the supermodelGenerator.py python script, for the multi-threading parameter.
          There is a missing "-" character for the "no-treads" elif section.
              if ThreadStatut == 1:
                  Thread.append("-no-gpu-thread")
              elif ThreadStatut == 2:
                  Thread.append("no-threads")
              else:
                  Thread.append("-gpu-multi-threaded")
          https://gitlab.com/recalbox/recalbox/-/blob/master/projects/configgen/configgen/generators/supermodel/supermodelGenerator.py
          • AxelR
            and choice 1 & 2 are inverted vs the inline help of ConfigModel3.ini
            • AxelR
              Also, this line:
              if QuadRendering == "1"
              should be
              if QuadRendering == 1
