    N64 controller and recalbox.
    GamePad/GPIO/USB encoder
    4.0.0 generic n64 usb controller
    9
    23
    31634
      Substring @dh04000 last edited by
      @dh04000 should check in the mupen doc, but i think they can't be mapped
      • Chris Matthes
        Chris Matthes @dh04000 last edited by Chris Matthes
        @dh04000 said in N64 controller and recalbox.:
        @Substring
        Never mind. I found the problem, I had an extra bracket far right to the controller name.
        To help other's with this controller. here's my controller config:
        [Generic USB Joystick]
        plugged = True
        plugin = 2
        mouse = False
        AnalogDeadzone = 4096,4096
        AnalogPeak = 32768,32768
        DPad R = hat(0 Right)
        DPad L = hat(0 Left)
        DPad D = hat(0 Down)
        DPad U = hat(0 Up)
        Start = button(9)
        Z Trig = button(7)
        B Button = button(8)
        A Button = button(6)
        C Button R = button(1)
        C Button L = button(3)
        C Button D = button(2)
        C Button U = button(0)
        R Trig = button(5)
        L Trig =
        Mempak switch =
        Rumblepak switch =
        X Axis = axis(0-,0+)
        Y Axis = axis(3-,3+)
        I unmapped the left trigger to use for the mupen64plus.cfg, where I mapped J0B4/B9 as exit emulation, J0B4/B6 as save state, and J0B4/B8 as Load state. These options are changed in the [Core Options].
        What is the command for Hat0 left or right though..... do you know Substring?
        thank u so much! works with my 1€ N64 USB Controller on ebay 😄
        dh04000 1 Reply Last reply Reply Quote 0
        • dh04000
          dh04000 @Chris Matthes last edited by
          @chris-matthes said in N64 controller and recalbox.:
          @Substring
          plugged = True
          plugin = 2
          mouse = False
          DPad U = hat(0 Up)
          Start = button(9)
          Z Trig = button(7)
          R Trig = button(5)
          L Trig =
          Mempak switch =
          Rumblepak switch =
          I'm glad that I was able to help you with my documentation. 🙂
          100.2k
