    Solved Updating recalbox 4.0.0 beta (2016/2/25) to newest beta
    updating recalbox 4.0.0 beta 2016225
    9509
    • ymdjackal
      ymdjackal last edited by
      Hi there,
      I am having the problem that my recalbox won't do the update. Download progress seems to hang after executing upgrade script. In addition, ssh is not responding after reaching that status.
      Any ideas?
      # sudo /recalbox/scripts/recalbox-upgrade.sh
      -sh: sudo: command not found
      # /recalbox/scripts/recalbox-upgrade.sh
      --2016-07-30 08:40:02--  http://archive.recalbox.com/4/rpi2-unstable/stable/last/boot.tar.xz
      Resolving archive.recalbox.com... 37.187.92.30
      Connecting to archive.recalbox.com|37.187.92.30|:80... connected.
      HTTP request sent, awaiting response... 200 OK
      Length: 5342624 (5.1M) [application/octet-stream]
      Saving to: '/recalbox/share/system/upgrade/boot.tar.xz.part'
      /recalbox/share/system/ 100%[=============================>]   5.09M  2.63MB/s    in 1.9s
      2016-07-30 08:40:04 (2.63 MB/s) - '/recalbox/share/system/upgrade/boot.tar.xz.part' saved [5342624/5342624]
      --2016-07-30 08:40:04--  http://archive.recalbox.com/4/rpi2-unstable/stable/last/root.tar.xz
      Length: 162298292 (155M) [application/octet-stream]
      Saving to: '/recalbox/share/system/upgrade/root.tar.xz.part'
      box/share/system/upgrad  26%[======>                       ]  40.49M  2.51MB/s    eta 52s
        The update is made in 2 steps :
        • download (that's what you're doing)
        • reboot to apply the update
        The download shouldn't hang. Do you have enough space left ?
        • ymdjackal
          ymdjackal last edited by ymdjackal
          Tried to delete the temporary files in folder upgrade and executed the script again. Unfortunately without success. The upgrade process can be seen shortly and then recalbox restarts again with the old version.
          Here is the upgrade error log
          cp: can't stat 'recalbox-boot.conf': No such file or directory
          And it seems to be right that there might be a disc space problem: The GUI says "0GB/13GB". /dev/Root/ has 150MB free disk space left.
          How can I delete unnecessary files? Roms are nearly none existent ...
            What does df -h report ?
            • ymdjackal
              here you go:
              # df -h
              Filesystem                Size      Used Available Use% Mounted on
              /dev/root               979.6M    762.1M    150.9M  83% /
              devtmpfs                236.9M         0    236.9M   0% /dev
              tmpfs                   241.1M         0    241.1M   0% /dev/shm
              tmpfs                   241.1M      4.0K    241.1M   0% /tmp
              tmpfs                   241.1M      2.4M    238.7M   1% /var
              tmpfs                   241.1M    164.0K    240.9M   0% /run
              /dev/mmcblk0p1           63.0M      6.6M     56.4M  10% /boot
              /dev/mmcblk0p3           13.4G    234.8M     12.5G   2% /recalbox/share
              • ymdjackal
                Does anyone have an idea?
                  rockaddicted last edited by rockaddicted
                  recalbox don't find your /boot/recalbox-boot.conf file. Some old, 4.0.0 alpha versions didn't had this files.
                  Try to create it manually, then retry an update :
                  • to remount /boot partition with write rights :
                    mount -o remount, rw /boot
                  • then this command to create the file :
                    echo -e "internal=/dev/mmcblk0p3\nsharedevice=INTERNAL" > /boot/recalbox-boot.conf
                  Now try to update the system using the /recalbox/scripts/recalbox-upgrade.sh script.
                  ymdjackal 1 Reply Last reply Reply Quote 1
                  • ymdjackal
                    ymdjackal @rockaddicted last edited by
                    @rockaddicted said in Updating recalbox 4.0.0 beta (2016/2/25) to newest beta:
                    Work like a charm! Many thanks to you @rockaddicted
                      you are welcome 😉
