    Troubleshooting games
    Emulator Arcade/PC/Console
    troubleshooting
    3962
    • derbaron
      derbaron last edited by
      Hello!
      i have a few Games that cause a "segmentation Fault" .. they work on PC..
      Any idea?
      retroarch -L /usr/lib/libretro/mame078_libretro.so --config /recalbox/share/s>
      Segmentation fault
      <der\ Boy\ in\ Monster\ Land\ (USA,\ Europe).zip -v
      RetroArch [INFO] :: === Build =======================================RetroArch [INFO] :: [CPUID]: Features:
      Built: Jul 21 2016
      RetroArch [INFO] :: Version: 1.3.4
      RetroArch [INFO] :: Git: 09e1119
      RetroArch [INFO] :: =================================================
      RetroArch [INFO] :: Config: loading config from: /recalbox/share/system/configs/retroarch/retroarchcustom.cfg.
      RetroArch [INFO] :: Loading dynamic libretro core from: "/usr/lib/libretro/mame078_libretro.so"
      RetroArch [INFO] :: Overrides: no core-specific overrides found at /recalbox/share/system/.config/retroarch/config/MAME 2003/MAME 2003.cfg
      RetroArch [INFO] :: Overrides: no game-specific overrides found at /recalbox/share/system/.config/retroarch/config/MAME 2003/Wonder Boy in Monster Land (USA, Europe).cfg
      RetroArch [INFO] :: Environ SET_VARIABLES.
      RetroArch [INFO] :: Remaps: core name: MAME 2003
      RetroArch [INFO] :: Remaps: game name: Wonder Boy in Monster Land (USA, Europe)
      RetroArch [INFO] :: Remaps: remap directory: /recalbox/share/system/.config/retroarch/config/remaps
      RetroArch [INFO] :: Remaps: no game-specific remap found at /recalbox/share/system/.config/retroarch/config/remaps/MAME 2003/Wonder Boy in Monster Land (USA, Europe).rmp
      RetroArch [INFO] :: Remaps: no core-specific remap found at /recalbox/share/system/.config/retroarch/config/remaps/MAME 2003/MAME 2003.rmp
      RetroArch [INFO] :: Environ GET_LOG_INTERFACE.
      RetroArch [INFO] :: Environ GET_VARIABLE mame2003-frameskip:
      RetroArch [INFO] :: 0
      RetroArch [INFO] :: Environ GET_VARIABLE mame2003-dcs-speedhack:
      RetroArch [INFO] :: enabled
      RetroArch [INFO] :: Environ PERFORMANCE_LEVEL: 10.
      RetroArch [INFO] :: Content loading skipped. Implementation will load it on its own.
      Segmentation fault
      • Nachtgarm
        Nachtgarm @derbaron last edited by
        @derbaron Maybe @subs can help on this. He's a true wizard most of the time 😉
          Hello
          Are you sure that your romset is for mame 2003 ?
          Need mame 0.78 romset may be check with clrmamrpro
          • derbaron
            derbaron last edited by rockaddicted
            Hi
            i think so...
            with rainbow islands for example:
            retroarch -L /usr/lib/libretro/mame078_libretro.so --config /recalbox/share/system/configs/retroarch/retroarchcustom.cfg /recalbox/share/roms/mame/rbisland.zip
            Segmentation fault
            i took this rom:
            Edit : link removed, no download links to copyrighted contents on the forum
              voljega Banned last edited by
              It's written mame 0.158 on your own link...
              Please read the arcade documentation on recalbox github wiki
                Don't "think so" but check the rom with clrmamepro, i'm sure it's not the rom version the mame core can emulate
                If you don't know how to use clrmamepro, have a look at our wiki 🙂
                And please remove your link 🙂
                • derbaron
                  ok sorry for the link!
                  well ok so segfault generally means it cant emulate.
                  thanks!
                    For every wonder boy game i know on arcade, there is a working one on the mame2003 core : the original game where you can ride a skate board, the second one where you have to reach a castle which is a d**n mazr, and the last one that is a shoot'em up (and awfully hard). They all work. Make sure you have th parent, not a split clone
                    • derbaron
                      thank you. i am still a novice with that roms
