    Controller doesn't work immediately.
    GamePad/GPIO/USB encoder
    doesnt immediately
    • Jotun
      Jotun last edited by
      I have both a Xbox 360 controller and a Logitech F310 hooked up and working in EmulationStation. But once I load a ROM nothing works for about a minute. I have to button mash my controllers before they work. My Xbox 360 controller light blinks so I know they are getting power. EmulationStation and Kodi work flawlessly (Expect for the occasional 360 controller freak out in Kodi.) I do not have this issue within RetroPie. But I have other issues with it that made me come to this. And I overall like this more.
      I am using a RPI3 with recalboxOS 4.0.0-beta4.
        Hello
        you need to edit recalbox.conf and active xboxdrv driver.
        https://github.com/recalbox/recalbox-os/wiki/recalbox.conf-(EN)
        it must resolved the problem
        ------------ D2 - XBOX Controllers ------------
        Xbox controllers are already supported, but xboxdrv can solve some compatibility issues
        Enable xboxdrv driver, disable this if you enabled ps3 controllers (0,1)
        controllers.xboxdrv.enabled=0
        Set the amount of controllers to use with xboxdrv (0..4)
