    Solved [SOLVED] TP-LINK TL-WN725N doesn't work
    tp-link tl-wn725n doesnt
    • tonyloco
      tonyloco Translator last edited by tonyloco
      Hi there,
      I'm trying to get working this Wifi dongle, but nothing. The weird thing is that it really works on Kodi, but not in Recalbox. How can it be possible. Thank you!
      Distracted and hyperactive gamer at Distrattivo
        Hi, there is a topic in the French forum about this dongle : https://forum.recalbox.com/topic/980/tuto-faire-fonctionner-la-carte-wifi-tp-link-tl-wn725n
        So first, if you are using a recalbox version 4.0, you must remount / partition with write right. Go on ssh, then :
        mount -o remount, rw /
        Then you must download a missing firmware :
        wget https://github.com/lwfinger/rtl8188eu/raw/master/rtl8188eufw.bin -O /lib/firmware/rtlwifi/rtl8188eufw.bin
        • tonyloco
          I read the french forum but I didn't find the first command. Now it works correctly. Thank you!
            good news, have fun 😉
