    Use controller D-pad instead of mouse in ScummVM?
    Emulator Arcade/PC/Console
    d-pad instead mouse scummvm
    • Ogre
      Ogre last edited by
      Hello, I'm using Recalbox CRT on a Pi 4 and I can't use the controller to move the cursor in ScummVM, it does work in RGB-Pi OS.
      Is there a fix for this? It's really hard to see the settings in that low resolution but it appears to be correct.
      fleafunk 2 Replies Last reply Reply Quote 0
      • fleafunk
        fleafunk @Ogre last edited by
        @Ogre I would also like this option to be available
        • fleafunk
          @Ogre Recalbox 9.2 introduced a new core for Scummvm that allows you to use the D-pad as a mouse, finally everything has been resolved.
