    RecalBox 9.2 - rpi5 - SSH issue
    recalbox 9.2 rpi5 ssh issue
    • Kaldrill
      Kaldrill last edited by
      Hi,
      I've just installed Recalbox 9.2 on my new raspberry pi 5. It seems to work correctly, It seems to be connected to my WIFI as I can see my IP address in the recalbox menu and in the web interface of my router.
      But I can't connect to it via SSH nor access the recalbox.local web interface (timeout on the connection).
      Is there a way to access error logs somewhere on the pi directly to trace what is going on ?
      Thanks
      poppadum 1 Reply Last reply Reply Quote 0
      • poppadum
        poppadum @Kaldrill last edited by poppadum
        @Kaldrill There are some logs in /recalbox/share/system/logs; probably init.log is the first place to look to make sure that /etc/init.d/S50dropbear (the ssh server) is being started.
        There are also logfiles in /var/log/samba (samba enables filesharing with Windows).
        Also check /var/log/wpa_supplicant.log to check the wifi has connected correctly.
        edit: /var/log is wiped at power off so you need to look at it while Recalbox is running; suggest connecting a keyboard and accessing the console directly.
        • Kaldrill
          @poppadum Thanks for the info, much appreciated. It's always good to know where to look.
          After a few restart the SSH server managed to start correctly. I'm still not sure to know what happened initially.
          Regarding the web interface the problem was a port conflict with an MQTT broker which was running on my computer for local development. I didn't find where to edit the MQTT broker to change the port but that's not a big issue.
          Thanks
          smokinjokeins 1 Reply Last reply Reply Quote 0
          • smokinjokeins
            smokinjokeins @Kaldrill last edited by
            @Kaldrill recalbox 9.2 , i downloaded the 9.2 zip file, how do i merge the 9.2 files to 8.1 recalbox, i needed the arcade joystiks workin, cannot open the manager to change to 1 position for it, thnx G, can you?
            101.4k
