    How can I change these Settings for pulse audio?
    settings pulse audio
    • Burni
      Burni last edited by
      Hi,
      I´m on a GPI Case with Raspery Pi Zero2 and Recalbox 9.1.
      Everything runs fine except I have soundlags/cracks with pulse audio diver and vsync enabled.
      Tried everything I found online but only got it a little better.
      Some games run fine without vsync but some are just not enjoyable.
      Alsathread audio driver works but have other problems. Wanna use pulse.
      So I discovered on a few pages this fix:
      I should edit /etc/pulse/default.pa
      this line:
      load-module module-udev-detect
      change to this:
      load-module module-udev-detect tsched=0
      For almost every user with the same problem it was fixed.
      So there comes my question:
      Where is this folder and file to be found?
      How can I change this line in Recalbox?
      Remember: I use it on a GPI Case. I can only put the SD-Cart into my PC to make edits. But I don´t find this folder or file.
      Where is the linux file strukture?
      sources:
      https://www.linuxquestions.org/questions/slackware-arm-108/rpi3-sarpi-retroarch-stuttering-sound-*finally*-fixed-via-pulse-audio-tsched-setting-4175671360/
      https://askubuntu.com/questions/371595/for-pulseaudio-what-does-tsched-do-and-what-are-the-defaults
      https://wiki.archlinux.org/title/PulseAudio/Troubleshooting
      100.7k
