    [Solved]Quick help: 64GB Sd Card formatting
    [solved]quick 64gb card formatting
    • flipbug
      flipbug last edited by
      Hi all! As in title, I just need help getting started. I have a 64GB SDcard. I've managed to format it as FAT32 using the suggested Minitool Partition Wizard (and a few other tools as well) and then put the OS files onto the SDcard, but the Pi won't boot.
      • flipbug
        Resolved by myself: used instructions found here: https://www.raspberrypi.org/documentation/installation/sdxc_formatting.md
          hello Wiki page : https://github.com/recalbox/recalbox-os/wiki/Installation-(EN)
          Start the SDCard formatter program and format the whole card in FAT32.
              For information : if you are using a 64Go SDCard, your formater software may force format in exFAT.
              So if you have this problem, you can try minitool partition wizard (windows only)
