    Dpad As stick
    GamePad/GPIO/USB encoder
    dpad stick
    • AJES
      AJES last edited by
      so I Purchased An GPI Case 2 and so it worked perfectly and everything was working great With Recalbox But There Was Little Bit Of A Challenge i tried 3D Dreamcast Games I Tried Sonic Adventure 2 But Well Moving Was Impossible As You Cant Move With The Dpad Only With A Stick Is There A Way To Like Well The Dpad Is THe Dpad But The Emulator Captures The Input As A Stick
      adam0509 1 Reply Last reply Reply Quote 0
      • adam0509
        adam0509 @AJES last edited by
        @AJES Hotkey + A then reconfigure button specifically for Dreamcast/Flycast ?
        AJES 1 Reply Last reply Reply Quote 0
        • AJES
          AJES @adam0509 last edited by
          @adam0509 nope still doesnt work
          • Magaki
            Magaki last edited by
            Hello,
            Didn't found a solution for portable mode, but I'm playing in docked mode, with an official controller with analog.
            Would be uncomfortable to play Dreamcast in portable mode, but each to his own 🙂
