    M30 2.4Ghz doesn't detect left/right axis
    GamePad/GPIO/USB encoder
    m30
    • manzurek
      manzurek last edited by
      The 2.4ghz USB receiver for the m30 has three different input modes. Hold the following buttons for about 5 seconds to switch mode.
      Home+Up: X-input (works for Recalbox)
      Home+Left: Nintendo Switch
      Home+Down: D-input (Genesis mini)
      https://misterfpga.org/viewtopic.php?t=4279
      jack-mcslay 1 Reply Last reply Reply Quote 0
      • jack-mcslay
        jack-mcslay @manzurek last edited by
        @manzurek I have the bluetooth version and I have similar issues. Trying to map the controls using the USB cable does not work; It reads Axis 1+ and Axis 0+ but not Axis 1- and Axis 0- so it can't map the whole D-Pad.
        Connecting via bluetooth everything is fine
        • jack-mcslay
          jack-mcslay @jack-mcslay last edited by
          @jack-mcslay Update: apparently it doesn't like working together with another M30 even on bluetooth
          • Damião
            Damião last edited by
            Hello,
            Many issues are reported with 8Bitdo controllers, it appears that this com from latest firmware updates provided by 8bitdo.
            Not all firmwares are supported by Recalbox, can you check yours using this table?
            https://wiki.recalbox.com/fr/hardware-compatibility/compatible-devices/8bitdo-on-recalbox
            Damião
            Recalbox 9.1 + NUC7I7BNH + SSD 2To
            2 Xbox Series Controllers + Wireless adapter
