    [RESOLVED] Can't get SF3:Third Strike Working!
    chete
    9
    13
    11865
    • ashkeboussi
      ashkeboussi last edited by
      Or any CPS3 game for that matter (like MvC2). Do i need a special version of the rom? I am using FBA:Libretro.
      • wsamh
        wsamh last edited by
        you need to have the chd folder for sf3.
        • ashkeboussi
          do i also put the SF3 rom in there? Can you just give me an example of the directory structure?
          • wsamh
            You would have two files. You would have the rom file and the chd folder. They both have to be in the rom folder for fba-libretro.
            • digitaLumberjack
              Hi, you can also download the no-cd version, that works like a charm.
              • jose-manuel-perez
                jose-manuel-perez last edited by
                Hi, Retroboy I've tried everything:   the chd file, versions "no cd" that I do wrong, we must change the rom? or only download it and add it enough? you can help a little. The issue does not seem easy. thanks, greetings
                • nickdj
                  nickdj last edited by
                  planetemu.net rom fb-alpha sfiii3-2 Just stuck the zipped file in the finalburnalphalibretro folder and it works. This is using a Raspberry Pi 2. ADMIN EDIT : for legal purpose, i don't want direct links to roms site on the forum...
                  RPi 2 Not overclocked Edimax EW-7811UN LogiLink BT0007A USB bluetooth V2.1 PS3 Controller RecalBox v3.2.8
                  • makfredo
                    makfredo last edited by
                    Yeah!!! That made the trick for me!!! I just couldn't make any CPS 3 rom I downloaded run in FbaLibretro... I think Retroboy needs to put a readme.txt file inside the fbalibretro folder with instructions.
                    • jose-manuel-perez
                      Where is the "FbaLibreto" file? , I can´t find it Solved , locate and confirm ,/recalbox/share/roms thanks
                      • digitaLumberjack
                        So resolved 🙂 Good game !
                        • frostyglitch
                          frostyglitch last edited by
                          I got this working on FBALibretro, but not on Mame.
                          • reivaax
                            reivaax last edited by
                            @Frosty, it's normal that doesn't work on mame. Only fba libretro support cps3 game. 😉
                            • kaihansen1
                              kaihansen1 last edited by
                              hi, i put the rom (download of coolrom and emuparadise)   and .CHD at FBA libreto and not work.... I try with more roms (europe, japan, no cd)  I ve got the bios Neogeo.zip at the same folder  rom/fba libreto any idea?? Thanks
