    Recalbox 9 on Raspi 3b does not start
    recalbox raspi does start
    • ando
      ando last edited by
      Hey, I had Recalbox 7.1.1. running on my Raspi 3.
      Now put the version 9 image on the SD Card, but the monitor shortly seems to connect, but then it says "no signal"
      I wrote the image on the card again, but it does not do anything.
      Any hints?
      ando 1 Reply Last reply Reply Quote 0
      • ando
        ando @ando last edited by
        @ando I tried the retropie image on the same sc card, that does work.
        What could be wrong with the Recalbox image?
        • romrom77
          romrom77 last edited by
          Hi,
          same problem, have a sd card with 8.0.2 in nespicase with PI3B works perfectly,
          Recalbox 9 clean install, boot, then lose signal (sometimes i get intermitent screen, 2 second, then black screen again...)
          Retropie and recalbox older version work
          • tiago_SF
            tiago_SF last edited by
            I have same problem here.
            Recalbox 9 doesn't boot when I try to use it on raspberry Pi.
            I had Recalbox 8 and it worked perfectly. I updated to 9 and it stopped to boot. I've made a clean install and it kept not booting.
            Urizen 1 Reply Last reply Reply Quote 0
            • Urizen
              Urizen @tiago_SF last edited by Urizen
              @tiago_SF A mi me pasaba igual, no habia manera de que funcionara con instalacion limpia de Recalbox 9, pero probe a grabar la imagen con el programa Etcher y me funcionó, con Win32 disk imager no, la razon de porque pasa esto la desconozco totalmente.
