    Unsolved Recalbox 9.x missing emulators
    recalbox 9.x missing
    1899
    • marcosdss
      marcosdss last edited by
      Recalbox version 9 is missing some emulators in the system, these emulators are the most popular ones. I had to migrate to recalbox version 7.2 to enjoy this emulator, I ask the developer to fix this error. Atomiswave does not have another etc
      marcosdss 1 Reply Last reply Reply Quote 0
      • marcosdss
        marcosdss @marcosdss last edited by marcosdss
        1 ) Wired internet network does not work
        2 ) Game settings, "Hide pre-installed games" option. it does not have
        3 ) Core settings are default for Retro FbaNeo or Mame FbaNeo, makes some rons not work, should have more core selection option
        4 ) In the rons folder there is the emulator that does not appear on the main screen as Atomiswave
        5 ) Missing emulator in rons folder, like Ps2 etc
        6 ) Crash on raspberry 4
        7 ) Bios all working green, and Rons asks Bios missing
        • Nazgulh
          Nazgulh last edited by
          given your harsh criticism I think you should look elsewhere
          and your request is incomplete read this Before posting
          • marcosdss
            marcosdss @Nazgulh last edited by
            If you think that this was a harsh criticism for me collecting a problem in your recalbox 9.0 system, and making a bulletin informing what happened, that for me was an offense, and knowing that it's not a big deal to have your website with support forum support and Discord, and even though recalbox is free, that was an offense! If you don't want to receive a bulletin reporting a problem with your recalbox system, you don't make the recalbox available for free, and you don't create a service and discussion channel such as a forum and Discord etc, (it's very ignorant of the part,) if you are going to make the recalbox available for free, you don't create a channel of discussion, to then ban people for no reason knowing that the channel has the discussion setting.
            He opens a website with a support channel and forum and discord and thinks it's bad to publish problems, bugs and errors in the recalbox system, it's complicated.
            On discord I published the related problems, I was mocked and humiliated by the adm and the support team, and I was still accusing of causing problems and offense, on the contrary the adm who attacked! I just defended myself! Because adm thinks he's the all-powerful guy, he threatened and banned him from discord, I didn't see humility in either of you.
            Se você acha que isso foi uma dura crítica para mim coletar um problema no seu sistema recalbox 9.0, e fazer um boletim informando o ocorrido, isso para mim foi uma ofensa, e saber que não é grande coisa ter seu site com fórum de suporte suporte e Discord, e mesmo que o recalbox seja gratuito, isso foi uma ofensa! Se você não deseja receber um boletim relatando um problema com seu sistema recalbox, você não disponibiliza o recalbox gratuitamente e não cria um canal de serviço e discussão como um fórum e Discord etc, (é muito ignorante da parte,) se vai disponibilizar o recalbox de graça, não cria um canal de discussão, para depois banir as pessoas sem motivo sabendo que o canal tem a configuração de discussão.
            Ele abre um site com canal de suporte e fórum e discord e acha ruim publicar problemas, bugs e erros no sistema recalbox, é complicado.
            No discord publiquei os problemas relacionados, fui zoado e humilhado pelo adm e equipe de suporte, e ainda fui acusado de causar problemas e ofensa, pelo contrario o adm que atacou! Eu apenas me defendi! Porque o adm acha que é o cara todo poderoso, ameaçou e baniu ele do discord, não vi humildade em nenhum de vocês
            marcosdss 2 Replies Last reply Reply Quote 0
            • marcosdss
              This post is deleted!
              • Topic has been marked as a question  marcosdss marcosdss
              • marcosdss
                  Scavy Global moderator @marcosdss last edited by
                  @marcosdss said in Recalbox 9.x missing emulators:
                  Hello
                  1. My internet system works (wired & bluetooth)
                  2. I have the option
                  3. I didn't understand your question
                  4. There are no emulators in roms folders. What do you mean ?
                  5. PS2 is avaible, but on PC only
                  6. When does it crash ? I have no crash
                    7 ) All my bios are avaible, green and works fine. Check the md5 signature.
                  Your sd card may be corrupted, or there may be a problem while flashing/installing the system.
