    Disable ScummVM widescreen
    Emulator Arcade/PC/Console
    scummvm
    • adam0509
      adam0509 last edited by
      Anybody knows how to disable ScummVM Widescreen ?
      I tryed this :
      • 1/1 ratio
      • 640x480 resolution
      • fullscreen=false (config file)
      • aspect_ratio=true (config file)
      Interestingly, putting mute=true doesn't mute any sound... Does those Config file really works ??? I had the same problem with Mupen config file... Seriously...
      Nothing works, any clues ?
      • adam0509
        Ok I resolved my problem
        First, the config file seems to be read only at Pi Launch, so manipualting it may need a reboot.
        The correct way is to launch ScummVM, then in menu select "Return to Launch Screen" then "Options"
        Stretch mode :
        • Pixel Perfect
        • Fit to window
        Now I can play Police Quest Swat on my Raspberry Pi with Pixel Perfect
