    Apple II (LinApple) - No sound in HDMI
    Emulator Arcade/PC/Console
    apple linapple sound hdmi
    • achelio
      achelio last edited by
      Hello,
      I'm using the standard emulator for Apple II (LineApple), and I can't make the sound work through HDMI, I only have sound through the P2 output (even though all other systems are working through HDMI without problems.
      I couldn't find how to change the LineApple options, anyone have a tip? Thanks in advance.
        Scavy Global moderator @achelio last edited by
        @achelio hello
        You have the problem on which card (pi3, pi4, pc) ?
        achelio morpheusdev 2 Replies Last reply Reply Quote 0
        • achelio
          achelio @Scavy last edited by
          @Scavy hello,
          Pi4
          • morpheusdev
            morpheusdev @Scavy last edited by
            Hi @Scavy,
            I experience the same problem with RPI3 too.
            As I remember the sound worked on the version 6.0, unfortunately I couldn't update sooner.
