    Accidentally switched on Recalbox RGB Dual, can't switch back to normal
    rgb dual crt
    • greeny123
      greeny123 last edited by
      Hello everyone,
      first of all: I'm completly new to the whole recalbox experience and probably as
      incompetent as it gets, so sorry, if my questions are dumb. Thanks for the great
      support of this Retro-Gaming miracle you all created over the past years, I'm a huge
      fan 🙂
      My recalbox ist connected via HDMI to my LG Oled.
      I tried some options in the system menu and switched (dumb as I am) the crt adapter
      option to "Recalbox RGB Dual". The system started anew an now the whole solution
      in the main menu is pretty low. Problem is: I can't change the crt adapter back to normal 😞
      and for the hell of it, i searched through the settings again and again and can't anything to help me. When
      I select the "CRT Adapter" in the "CRT Settings", then there is no other option to choose than "Recalbox
      RGB Dual".
      I hope my explanation is understandable, English is not my first language ;D
      Anyway, really big thanks for your help, guys 🙂
      • greeny123
        Edit:
        This is the only information I found about this in the logs. Maybe this helps somehow.
        And here a pic of the missing options to choose if I click on "CRT Adapter":
        • poppadum
          poppadum last edited by
          I would be tempted to use Reset to factory settings in the Advanced Settings menu as explained in the wiki.
          It won't delete your games but will reset your config files and should get rid of any CRT-specific settings.
          greeny123 2 Replies Last reply Reply Quote 0
          • greeny123
            greeny123 @poppadum last edited by
            @poppadum Thanks, didn't know that this won't reset my games! I'll try this! 🙂
            • greeny123
              @poppadum It worked! The reset helped. Thanks 🙂
