    8bitdo pro 2 wired how to force Android mode?
    GamePad/GPIO/USB encoder
    8bitdo wired pro2
    3545
    • pantoufle
      pantoufle last edited by pantoufle
      Hi,
      I'm using a 8bitdo pro 2 wired, and the default mode ist S-Input for Nintendo Switch.
      So before you connect the controller, hold B-button + start to switch to D-Input for Android-Mode, to be able to use it in Recalbox.
      But each time an emulator is launched, it is necessary to disconnect / reconnect the controller because it has been switched to another mode.
      Is it possible to force the D-Input to no longer have this issue?
      Shingohky 1 Reply Last reply Reply Quote 0
      • Shingohky
        Shingohky @pantoufle last edited by
        @pantoufle
        Hello the problem will be solved in the version 8.2. of Recalbox 😁
        pantoufle 2 Replies Last reply Reply Quote 0
        • pantoufle
          pantoufle @Shingohky last edited by
          @Shingohky said in 8bitdo pro 2 wired how to force Android mode?:
          Good news, thanks. 🙂
          • pantoufle
            Hello,
            I updated to Recalbox 9.0, and unfortunately the issue still occurs.
            Do you have any recommendations?
            Kind regards,
            Pantoufle
            • Shingohky
              @pantoufle hello you have to reconfigure your controller in the recalbox options. behind the 8 bit do pro 2 you have a button that allows you to switch in the different modes, select D-input and then select reconfigure the controller in the recalbox menu options and it should work....i followed this procedure for me and it worked
              pantoufle 1 Reply Last reply Reply Quote 1
              • pantoufle
                pantoufle @Shingohky last edited by pantoufle
                Hello @Shingohky,
                There is no button to change the mode on the wired version:
                • https://www.8bitdo.com/pro2-wired-controller/
                • https://download.8bitdo.com/Manual/Controller/Pro2-wired/pro2-wired.pdf
