    Unsolved Several ROM folders ?
    several rom folders
    • ssj17vegeta
      ssj17vegeta last edited by
      Hello all, been experimenting for my first time with Recalbox (which I must say is very well polished).
      I've installed it on a fresh mini-PC (so x86_64) by using the provided image (recalbox-x86_64.img.xz). It works well. Transferred some ROMs, tried emulators/network/SSH/controllers... everything works great.
      I'm facing a problem though.
      Recalbox is installed on an SSD whose size is limited, and I would like to move some ROM folders on an HDD I've plugged on my PC (SATA, appears mounted on /recalbox/share/externals/usb0).
      Basically, I would like to keep the 8-16 bits ROMs on the HDD, since they will be loaded quite fast anyway due to their size), and put heavy ones (Wii, PS2, PSX) on the SSD.
      I thought "hey no biggie, just pop in some symlinks and go". Problem, the /recalbox/share partition is formated in exFAT which doesn't support soft/hard links 😬.
      Also tried altering /etc/fstab and doing some "bind mounts" after doing ( mount -o remount,rw /) to no avail (already done it before on another computer, so I'm familiar with the procedure).
      So my question is : where do I go from there ? I thought about reformatting the share partition to ext4 and moving the data back on it, but wouldn't that break any future update ? Since Recalbox provides a polished experience, I wouldn't want to be "too specific" and make upgrading a hassle.
      Is there a feature resembling the ones you made for config overrides (where it searches several folders in a specific priority) where ES would search several folders just like :
      /recalbox/share/roms/
      /recalbox/share/externals/usb0/roms
      /myMountPoint/roms
      • Wizzard
        Wizzard last edited by
        What about creating a subfolder in your roms/platform folder and mounting your bigger drive there?
