    Help to connect two bluetooth controllers
    GamePad/GPIO/USB encoder
    ipega bluetooth
    • gerickt
      gerickt last edited by
      hi guys, I have managed to successfully connect my control bluetooth ipega 9021, works perfect (thanks to Ramstein http://blog.recalbox.com/forums/topic/ipega-9021-dont-work/) The problem is now, when I want to connect the second bluetooth control ipega same model 9021 ... recalbox recognize it, let me set for the Gamepad0 P1 and P2 for the Gamepad1. But after a few seconds the second "Gamepad1" control is automatically disconnected ... somebody could help me?
      • DAM
        DAM last edited by
        Hi, i have some problem. I used Ipega 9021 and a PS3 Sixad controller and one SFC30 8Bitdo too.
        I edit the script according the sugestion on forum: https://forum.recalbox.com/topic/2997/two-or-more-bluetooth-controls and the old version of forum http://blog.recalbox.com/forums/topic/ipega-9021-dont-work/
        In my case the sript 10-local.rules was so:
        bluetoothd -u
        sleep 5
        killall bluetoothd
        SUBSYSTEM=="input", ATTRS{uniq}=="number of bluetooth of Ipega 9021 Controller", MODE="0666", ENV{ID_INPUT_JOYSTICK}="1"
        SUBSYSTEM=="input", ATTRS{uniq}=="number of bluetooth of PS3 Controller", MODE="0666", ENV{ID_INPUT_JOYSTICK}="1"
        SUBSYSTEM=="input", ATTRS{uniq}=="number of bluetooth of SFC30 8Bitdo Controller", MODE="0666", ENV{ID_INPUT_JOYSTICK}="1"
        So i resolve the problem with controller, but after pair the controller, you can to define what is the first, second and third controller in ES options.
        I used 2 bluetooth adapter and work very well in games like Cadillacs and Dinosaurs on FBA.
        paolm 1 Reply Last reply Reply Quote 0
          Necro-ing topics is bad for my sight 😉
          • paolm
            paolm @DAM last edited by paolm
            @dam Hi friend , i am very new guy on this, please help me. I dont have this file "10-local.rules", only 99-joysticks-exotics.rules, 99-sixpair.rules and
            99-wiimote.rules. In 99-joysticks-exotics.rules i try to modify and add this lines that you mentioned but i dont have permission to write .. What can i do ? Tnks for now
            101.0k
