    Two or more Bluetooth controls?
    ipega bluetooth
    • gerickt
      gerickt last edited by
      Hello friends, I have set my bluetooth iPega 9021 Control properly, adding this line in the path /etc/udev/rules.d/10-local.rules
      SUBSYSTEM=="input", ATTRS{name}=="PG-9021", MODE="0666", ENV{ID_INPUT_JOYSTICK}="1"
      SUBSYSTEM=="input", ATTRS{name}=="GamePad", MODE="0666", ENV{ID_INPUT_JOYSTICK}="1"
      and it works perfectly ... the problem I have is that when you connect a bluetooth 2nd or third command of the same model, after a few seconds will automatically disconnect if connect in a different order, the first works well and the second is disconnected ... I must add something else in configuration files? to run two Bluetooth controls at the same time? Thanks for your time! regards
      • gerickt
        solved using another bluetooth dongle 3.0
        • alvinpark
          alvinpark last edited by
          I have the same question. Any suggestions friends? ---------------------------------------------------------------------------- Thanks & Regards, Alvin Park Internet Marketing
