    [Dreamcast] Flycast not working with some games
    Emulator Arcade/PC/Console
    [dreamcast] flycast
    6017
    • hokuem
      hokuem last edited by
      Bonjour/Hi,
      I just upgraded from a Pi3 to a Pi4 (both using 8.1.1), and noticed somes Dreamcast games that were working before (Hydro Thunder, Power Stone 2) now only show a black screen after boot. I realize it must be because Pi3 was using Reicast while Pi4 switched to Flycast. My other games still work.
      I read that Recalbox won't support Redream because it's closed source, so my question is: do you have any plans to add Reicast support as a backup on Pi4 so we can select it for games that don't work on Flycast?
      Otherwise, is there a way for users to add Reicast? Hoping it's not too complicated, as from my limited experience on Recalbox so far, the less I tinker with it, the better it runs. 😅
      By the way, the roms are the recommended TOSEC GDI format converted to .chd, and as I said, were working fine on Pi3 + Reicast, so it's not that.
      Merci et Joyeux Noël!
        Scavy Global moderator @hokuem last edited by
        @hokuem hi
        concerning dreamcast games, i hardly recommand you get one from the REDUMP romset, converted to .chd if you want to get more space ^^
        Reicast is no more developped, Flycast took its place.
        For a Dreamcast use, a RPi4 is a better choice 🙂
        hokuem 2 Replies Last reply Reply Quote 0
        • hokuem
          hokuem @Scavy last edited by
          @Scavy said in [Dreamcast] Flycast not working with some games:
          @hokuem hi
          Hi @Scavy , on the Recalbox Wiki, both the Flycast page and the Dreamcast FAQ recommend TOSEC instead of REDUMP, is that no longer the recommendation?
          I will try Redump roms to see if they work better and will revert here, thanks.
          • hokuem
            Hi @Scavy, unfortunately, the REDUMP roms don't work either. However, instead of a black screen, I see a menu with play/files/music/settings, but it still won't start the games.
            Any other ideas for roms that don't work with Flycast (but work fine on Reicast) ? Thank you.
              @hokuem did you check your bios ?
              I got a redump romset (in chd version), all my games launch with Flycast. It seems there's something else going wrong.
              hokuem 1 Reply Last reply Reply Quote 0
              • hokuem
                Thanks for taking the time to check. Do you know which version you have between Europe or USA? Maybe that's my issue...
                  @hokuem said in [Dreamcast] Flycast not working with some games:
                  hi most of my set is EUR version.
                  • hokuem
                    For anyone stumbling on this thread later:
                    • I tried all possible rom combinations (USA/Europe, Tosec/Redump, etc) and none was working for these 2 games.
                    • I started trying to change some Retroarch settings (ex: high level emulation, windows CE, etc) for Flycast and the games started to work. I thought it was the settings, but when I reverted everything to see which one exactly made the difference, the games still worked...
                    So basically, solution is: touch a retroarch setting, restart the game. Once the game work, revert the setting you changed, and the game will continue working afterwards, even after a full shutdown. 🤷
