    Shanwan vibration
    GamePad/GPIO/USB encoder
    shanwan control
    • ketorock
      ketorock last edited by
      Hi,   I've got a Shanwan Sixaxis and Raspberry Pi 2 with the last Beta. The RB has no problem with these controller, but there is just one thing, the Shanwan controller is all the time with vibration activated. Do you know what should I do to have a corrected vibration (or just desactivate it)?   Thanks
      Fuera del alcance del bostezo universal . Redactor en @AparteMagazine. Comunicación Audiovisual. Sevilla-Porto-Bayern
      • ketorock
        UP
          voljega Banned last edited by
          Vibration aren't workin nor activated on recalbox so this a really strange bug, you'll need the help from someone from the dev team... @acris maybe ?
            I dot know, may be @rockaddicted or @subs will have a idea.
              the vibration happens once the new BT master is set on the shanwan. Even if you unplug/replug it on usb, you still have the problem ?
              101.4k
