    Kodi 360 Controller defaults 4.0.0 beta 3
    kodi 360 contro
    • sgorveatt
      sgorveatt last edited by
      First of all thanks for the great OS. I'm a bit different than most, I believe, in that I mainly used this distro for Kodi. I know there are other distros/OS's that specialize in Kodi, but this one just seems to work best with a wireless 360 controller. I've been using Kodi since I modded an original xbox, so a controller seems like the right way to use kodi for me. Now for my issue. So I upgraded from 4.0.0 beta 1 to 4.0.0 beta 3 and I noticed the default Kodi controls for the 360 controller have changed. I felt like in beta 1 you had it almost perfect and now things seem all wrong. The right analog stick used to control volume now it acts as a d pad. Also the buttons are all mixed up while video is playing. Is this a bug, or is this the planned setup? Is there a reason for not making defaults as close to what Kodi uses?http://kodi.wiki/view/Xbox_360_Wireless_Controller I've had trouble customizing the controls, so for now I'll go back to beta 1.
        Hello do you have actived xboxdrv driver in recalbox.conf ? do you have reconfigure your gamepad after your update ?
        • sgorveatt
          I do/did have xboxdrv driver activated. I've never had to configure the 360 controller. It's just works out of the box for me. I'm just not satisfied with Kodi defaults. <span style="line-height: 1.5;">What files would i have to copy from beta 1 to the latest Kodi version, if i wanted to keep the old Kodi defaults? Or is it not as simple as copying files?</span>
