    ArduinoJoystickLibrary and multiple gamepad
    GamePad/GPIO/USB encoder
    multiple gamepad
    • drj59
      drj59 last edited by
      Hello everyone,
      I use the library ArduinoJoystickLibrary to create 4 gamepads.
      In Windows, I see one controller with the four distincts gamepad, but in Recalbox, only the first is working, anyone have an idea about how I can have the 3 others working ?
      thanks in advance
      https://github.com/MHeironimus/ArduinoJoystickLibrary
      The Arduino code
      #include <Wire.h>
      #include <Joystick.h>
      #define JOYSTICK_COUNT 4
      Joystick_ Joystick[JOYSTICK_COUNT] = {
        Joystick_(0x03, JOYSTICK_TYPE_GAMEPAD, 14, 0, true, true, false, false, false, false, false, false, false, false, false),
        Joystick_(0x04, JOYSTICK_TYPE_GAMEPAD, 14, 0, true, true, false, false, false, false, false, false, false, false, false),
        Joystick_(0x05, JOYSTICK_TYPE_GAMEPAD, 14, 0, true, true, false, false, false, false, false, false, false, false, false),
        Joystick_(0x06, JOYSTICK_TYPE_GAMEPAD, 14, 0, true, true, false, false, false, false, false, false, false, false, false)
      // 8 bytes of data that we get from the controller
      struct {
          // bits: 0, 0, 0, start, y, x, b, a
          unsigned char data1;
          // bits: 1, L, R, Z, Dup, Ddown, Dright, Dleft
          unsigned char data2;
          char stick_x;
          char stick_y;
      } N64_status_1;
      struct {
          char stick_x;
          char stick_y;
      } N64_status_2;
      struct {
          char stick_x;
          char stick_y;
      } N64_status_3;
      struct {
          char stick_x;
          char stick_y;
      } N64_status_4;
      void setup() {
        Wire.begin();
        Serial.begin(115200);
        for (int index = 0; index < JOYSTICK_COUNT; index++)
          Joystick[index].setXAxisRange(-80, 80);
          Joystick[index].setYAxisRange(-80, 80);
          Joystick[index].begin();
      void loop() {
        Wire.requestFrom(8, 4);    // request 4 bytes from peripheral device #8
        while (Wire.available()) { // peripheral may send less than requested
        N64_status_1.data1 = Wire.read(); // receive a byte as character
        N64_status_1.data2 = Wire.read();
        N64_status_1.stick_x = Wire.read();
        N64_status_1.stick_y = Wire.read();
        Joystick[0].setXAxis(N64_status_1.stick_x);
        Joystick[0].setYAxis(N64_status_1.stick_y);
        Joystick[0].setButton(0, N64_status_1.data1 & 128 ? 1:0);//A
        Joystick[0].setButton(1, N64_status_1.data1 & 64 ? 1:0);//B
        Joystick[0].setButton(2, N64_status_1.data1 & 32 ? 1:0);//Z
        Joystick[0].setButton(3, N64_status_1.data1 & 16 ? 1:0);//start
        Joystick[0].setButton(4, N64_status_1.data1 & 0x08 ? 1:0);//Dup
        Joystick[0].setButton(5, N64_status_1.data1 & 0x04 ? 1:0);//Ddown
        Joystick[0].setButton(6, N64_status_1.data1 & 0x02 ? 1:0);//Dleft
        Joystick[0].setButton(7, N64_status_1.data1 & 0x01 ? 1:0);//Dright
        Joystick[0].setButton(8, N64_status_1.data2 & 32 ? 1:0);//L
        Joystick[0].setButton(9, N64_status_1.data2 & 16 ? 1:0);//R
        Joystick[0].setButton(10, N64_status_1.data2 & 0x08 ? 1:0);//Cup
        Joystick[0].setButton(11, N64_status_1.data2 & 0x04 ? 1:0);//Cdown
        Joystick[0].setButton(12, N64_status_1.data2 & 0x02 ? 1:0);//Cleft
        Joystick[0].setButton(13, N64_status_1.data2 & 0x01 ? 1:0);//Cright
        Joystick[0].sendState();
        Wire.requestFrom(16, 4);    // request 4 bytes from peripheral device #16
        N64_status_2.data1 = Wire.read(); // receive a byte as character
        N64_status_2.data2 = Wire.read();
        N64_status_2.stick_x = Wire.read();
        N64_status_2.stick_y = Wire.read();
        Joystick[1].setXAxis(N64_status_2.stick_x);
        Joystick[1].setYAxis(N64_status_2.stick_y);
        Joystick[1].setButton(0, N64_status_2.data1 & 128 ? 1:0);//A
        Joystick[1].setButton(1, N64_status_2.data1 & 64 ? 1:0);//B
        Joystick[1].setButton(2, N64_status_2.data1 & 32 ? 1:0);//Z
        Joystick[1].setButton(3, N64_status_2.data1 & 16 ? 1:0);//start
        Joystick[1].setButton(4, N64_status_2.data1 & 0x08 ? 1:0);//Dup
        Joystick[1].setButton(5, N64_status_2.data1 & 0x04 ? 1:0);//Ddown
        Joystick[1].setButton(6, N64_status_2.data1 & 0x02 ? 1:0);//Dleft
        Joystick[1].setButton(7, N64_status_2.data1 & 0x01 ? 1:0);//Dright
        Joystick[1].setButton(8, N64_status_2.data2 & 32 ? 1:0);//L
        Joystick[1].setButton(9, N64_status_2.data2 & 16 ? 1:0);//R
        Joystick[1].setButton(10, N64_status_2.data2 & 0x08 ? 1:0);//Cup
        Joystick[1].setButton(11, N64_status_2.data2 & 0x04 ? 1:0);//Cdown
        Joystick[1].setButton(12, N64_status_2.data2 & 0x02 ? 1:0);//Cleft
        Joystick[1].setButton(13, N64_status_2.data2 & 0x01 ? 1:0);//Cright
        Joystick[1].sendState();
        Wire.requestFrom(32, 4);    // request 4 bytes from peripheral device #32
        N64_status_3.data1 = Wire.read(); // receive a byte as character
        N64_status_3.data2 = Wire.read();
        N64_status_3.stick_x = Wire.read();
        N64_status_3.stick_y = Wire.read();
        Joystick[2].setXAxis(N64_status_3.stick_x);
        Joystick[2].setYAxis(N64_status_3.stick_y);
        Joystick[2].setButton(0, N64_status_3.data1 & 128 ? 1:0);//A
        Joystick[2].setButton(1, N64_status_3.data1 & 64 ? 1:0);//B
        Joystick[2].setButton(2, N64_status_3.data1 & 32 ? 1:0);//Z
        Joystick[2].setButton(3, N64_status_3.data1 & 16 ? 1:0);//start
        Joystick[2].setButton(4, N64_status_3.data1 & 0x08 ? 1:0);//Dup
        Joystick[2].setButton(5, N64_status_3.data1 & 0x04 ? 1:0);//Ddown
        Joystick[2].setButton(6, N64_status_3.data1 & 0x02 ? 1:0);//Dleft
        Joystick[2].setButton(7, N64_status_3.data1 & 0x01 ? 1:0);//Dright
        Joystick[2].setButton(8, N64_status_3.data2 & 32 ? 1:0);//L
        Joystick[2].setButton(9, N64_status_3.data2 & 16 ? 1:0);//R
        Joystick[2].setButton(10, N64_status_3.data2 & 0x08 ? 1:0);//Cup
        Joystick[2].setButton(11, N64_status_3.data2 & 0x04 ? 1:0);//Cdown
        Joystick[2].setButton(12, N64_status_3.data2 & 0x02 ? 1:0);//Cleft
        Joystick[2].setButton(13, N64_status_3.data2 & 0x01 ? 1:0);//Cright
        Joystick[2].sendState();
        Wire.requestFrom(64, 4);    // request 4 bytes from peripheral device #64
        N64_status_4.data1 = Wire.read(); // receive a byte as character
        N64_status_4.data2 = Wire.read();
        N64_status_4.stick_x = Wire.read();
        N64_status_4.stick_y = Wire.read();
        Joystick[3].setXAxis(N64_status_4.stick_x);
        Joystick[3].setYAxis(N64_status_4.stick_y);
        Joystick[3].setButton(0, N64_status_4.data1 & 128 ? 1:0);//A
        Joystick[3].setButton(1, N64_status_4.data1 & 64 ? 1:0);//B
        Joystick[3].setButton(2, N64_status_4.data1 & 32 ? 1:0);//Z
        Joystick[3].setButton(3, N64_status_4.data1 & 16 ? 1:0);//start
        Joystick[3].setButton(4, N64_status_4.data1 & 0x08 ? 1:0);//Dup
        Joystick[3].setButton(5, N64_status_4.data1 & 0x04 ? 1:0);//Ddown
        Joystick[3].setButton(6, N64_status_4.data1 & 0x02 ? 1:0);//Dleft
        Joystick[3].setButton(7, N64_status_4.data1 & 0x01 ? 1:0);//Dright
        Joystick[3].setButton(8, N64_status_4.data2 & 32 ? 1:0);//L
        Joystick[3].setButton(9, N64_status_4.data2 & 16 ? 1:0);//R
        Joystick[3].setButton(10, N64_status_4.data2 & 0x08 ? 1:0);//Cup
        Joystick[3].setButton(11, N64_status_4.data2 & 0x04 ? 1:0);//Cdown
        Joystick[3].setButton(12, N64_status_4.data2 & 0x02 ? 1:0);//Cleft
        Joystick[3].setButton(13, N64_status_4.data2 & 0x01 ? 1:0);//Cright
        Joystick[3].sendState();
        delay(50);
      This is how it appear in windows :
      One controller
      with 4 gamepads
      I can receive the input of each gamepad
      but in Recalbox only one appear "LLC ARDUINO MICRO"
      If someone have an idea.... thanks in advance
      • drj59
        I found the issue, need to add "usbhid.quirks=0x2341:0x8037:0x040" into the cmdline.txt file for an Arduino Micro
        see wiki : https://github.com/MHeironimus/ArduinoJoystickLibrary/wiki/FAQ
        0zzy 1 Reply Last reply Reply Quote 0
        • 0zzy
          0zzy @drj59 last edited by
          @drj59 said in ArduinoJoystickLibrary and multiple gamepad:
          Hi @drj59 i'm using the same library, with two arduino nano.
          I have a strange issue moving on EmulationStation frontend, when I press a button or move joystic, every signle click is doubled.
          In game does not happen, and this home made encoder, works fine.
          Have you got the same problem?
