    Solved [Solved]FBA_libretro SF Games CPS 3 slow : disabled rewing please
    cps slow disabled rewing
    5542
      paradadf Staff last edited by
      Hi! The last time I played these games was on Recalbox v3 and I remember they were running without any lag nor sound problem. But today I tested them on v4.0.0 beta 3 and they were running very slow and with sound problems. On BestArcade4Recalbox all three are marked as green, so I wanted to ask your if you have the same behavior as myself or something got broken 😄 The roms I used are: Street Fighter III 2nd Impact: Giant Attack (USA 970930) sfiii2 Street Fighter III 3rd Strike: Fight for the Future (Euro 990608) sfiii3 Street Fighter III: New Generation (Euro 970204) sfiii Thanks!   EDIT: I have the right romset 😉
      kaihansen1 1 Reply Last reply Reply Quote 0
        Rewind option is enabled ?
          It was!!! 😄 I learned something new today, thank you! Turning the rewind option off solved the problem.
          • kaihansen1
            kaihansen1 @paradadf last edited by
            @paradadf the new generation work perfect in Beta 4.
            ..... but i cannot work the 3rd Strike and 2nd impact. I ve got the same roms but i cant
              paradadf Staff @kaihansen1 last edited by
              @kaihansen1 If the roms don't even start, then you have the wrong romset, that simple.
              • kaihansen1
                @paradadf ok, i will try again......Romset V0.2.97.30...thats right???
                  paradadf Staff @kaihansen1 last edited by paradadf
                  @kaihansen1 no, romset 0.2.97.37 for fba_libretro since Recalbox v3.3.0-b15
                  https://github.com/recalbox/recalbox-os/wiki/Advanced-Arcade-on-Recalbox-(EN)
