    Add Neo Geo as a separated emulator
    neo geo separated
    • raulval82
      raulval82 last edited by
      Hi! I have all Neo Geo games working with FBA as a separated emulator, I created a new folder in roms, and is possible to share modifing /etc/samba/smb.conf like you told me, but will this be replaced with each update?
      • digitaLumberjack
        Hi, yes all systems files are overwritten on update.
        • raulval82
          Then is possible to add this as a permanent emulator in recalbox? I think that NeoGeo is important enought to have it's own menu. If not, how can I add music to this??
          • digitaLumberjack
            It's not possible as es_systems.cfg will be overwritten. You can copy a directory in /root/.emulationstation/themes/simplesvg and change the system.ogg of the new file to add your own music. Or you can create your own themes : https://github.com/digitalLumberjack/recalbox-os/wiki/Edit-emulationstation-themes-(EN)
