    JOYSTICK NOT WORKING IN PPSSPP after first use
    GamePad/GPIO/USB encoder
    joystick ppsspp
    • TheWhite
      TheWhite last edited by TheWhite
      Hi,
      Dragonrise joystick will not work after first use in ppsspp. Once you exit the game it changes the controls.ini from this
      [ControlMapping]
      An.Down = 1-39,10-4002
      An.Left = 1-38,10-4001
      An.Right = 1-40,10-4000
      An.Up = 1-37,10-4003
      Analog limiter = 1-60
      Circle = 1-52,10-190
      Cross = 1-54,10-189
      Down = 1-20,10-20,10-4002
      L = 1-45,10-194,10-193
      Left = 1-21,10-21,10-4001
      Pause = 1-111,10-4
      R = 1-51,10-195,10-192
      RapidFire = 1-59
      Rewind = 1-67
      Right = 1-22,10-22,10-4000
      Select = 1-66,10-196
      SpeedToggle = 1-68
      Square = 1-29,10-191
      Start = 1-62,10-197
      Triangle = 1-47,10-188
      Unthrottle = 1-61
      Up = 1-19,10-19,10-4003
      The above joystick works in the games.
      To this where joystick no longer works
      [ControlMapping]
      Circle = 10-190
      Cross = 10-189
      Down = 10-4002
      L = 10-193
      Left = 10-4001
      Pause = 10-4
      R = 10-192
      Right = 10-4000
      Select = 10-196
      Square = 10-191
      Start = 10-197
      Triangle = 10-188
      Up = 10-4003
      [default]
      Cross = 1-54,10-189
      Pause = 1-111,10-4
      RapidFire = 1-59
      Rewind = 1-67
      SpeedToggle = 1-68
      Start = 1-62,10-197
      Unthrottle = 1-61
      Buttons continue to work but Joystick no longer works. Doing reset to factory then the joystick works again the one time until exit and go back in to game PPSSPP.
      If using controller like xbox 360 /PS4 etc. all works fine.
      Unable to edit control.ini as it gets rewritten to the non working text.
      I have tried other USB controller boards and does the same.
      • Alvin
        Alvin Banned @TheWhite last edited by
        @thewhite
        Did you set up your Raspberry Pi (I assume you use one) like this:
        https://wiki.recalbox.com/en/tutorials/controllers/gpio/gpio-controllers
        Look at the "Configuration" Part
        https://wiki.recalbox.com/en/tutorials/controllers/gpio/set-until-4-features-on-each-gpio-port
