    [Solved]Return from MAME/SNES/PSX to ES without Keyboard Esc
    [solved]return mamesnespsx keyboard esc
    • mcdinata
      mcdinata last edited by
      Hi, If you have tips on how to return to ES from any systems ( SNES/PSX/MAME) without pressing Keyboard Esc key. I use Logitech F310 as game controller, no issue with keymapping inside the game. Thanks in advance
        Please read Wiki and Manual before posting on the forum : https://github.com/recalbox/recalbox-os/wiki/Manual-(EN)#duringgame-special
        • mcdinata
          Thank you for the prompt reply. Appreciate it!! Problem solved
