    Solved FBNeo automatically disables RetroAchievements hardcode mode (Recalbox 8.1.1)
    Emulator Arcade/PC/Console
    fbneo hardcode retroachievment
    • Ridera37
      Ridera37 last edited by Ridera37
      Hello,
      I've been using Recalbox and RetroAchievements for several years now. I'm currently using a clean install of Recalbox 8.1.1 on a Raspberry Pi 3.
      I configured "fbneo-allow-patched-romsets" to "disabled" in "retroarch-core-options.cfg". I correctly configured RetroAchievements support and enabled the hardcore mode.
      When I run a SNES (Snes9x 2010 1.52.4) or Genesis (PicoDrive 1.99) or GBA (mGBA) rom, the hardcore mode is correctly activated and hardcore points are granted when I pass an achievement.
      But when I run a FBNeo rom, the hardcore mode gets automatically disabled. I still can manually force enable it using in the "Settings / Achievements / Hardcode Mode" emulator menu. Whether I force enabled it or not, when I quit the rom, then "cheevos_hardcore_mode_enable" is saved to "false" in "retroarchcustom.cfg". From this point the hardcore mode is disabled for all cores, unless I edit "retroarchcustom.cfg" and restart Recalbox.
      Is this a known issue ?
      How can this be fixed (i.e. be able to use the hardcore mode without manual configuration each time FBNeo is used) ?
      Thank you for your help.
      • Ridera37
        A solution is described in the french version of this post, see https://forum.recalbox.com/topic/27792/fbneo-désactive-automatiquement-le-mode-hardcore-de-retroachievements-rb-8-1-1
