    Recalbox Electron 8.1.1 Emulation Station main menu music issue.
    recalbox electron 8.1.1 station main music issue
    • ArthCore
      ArthCore last edited by
      I installed the new version of Recalbox Electron 8.1.1 on my Raspberry Pi 3b+.
      And in main menu music freezes, I try start a random game - there isn't any problems with music or sound. After that I exit to main menu (Emulation Station) and again music freezes.
      I found a way how to fix it - in sound options need to choose a different output source - for example analog headphones, wait a few seconds, and after again need to choose the Hdmi/displayport. Music in menu starts playing correctly but until restarting the Raspberry or starting game and exit from it.
      I'm shure that problem not in the Raspberry Pi or SDcard. Because I try this version it on another new SDcard. The situation is same. Moreover I have the SDcard with older version of Recalbox Dragonblaze and there isn't any problems with music in main menu.
      Please give me any Ideas where is the problem can be.
      DIEGOSS 1 Reply Last reply Reply Quote 0
      • DIEGOSS
        DIEGOSS @ArthCore last edited by
        @arthcore também estou com o mesmo problema, e também as músicas ficam lentas, elas tocam mas com lentidão.
        ArthCore 1 Reply Last reply Reply Quote 0
        • ArthCore
          ArthCore @DIEGOSS last edited by
          There is have a guide how to fix this bug:
          https://wiki.recalbox.com/en/tutorials/audio/fix-emulationstation-sound-issues
          I tried make this way, and used MobaXterm. But after that music in Emulation station doesn't plays at all.
          Perhaps it must work in older versions of Recalbox?
          • enzo5
            enzo5 last edited by
            The audio freezing in Recalbox 8.1.1 may be due to output settings. Try setting HDMI as default, adjusting audio settings, or testing a different HDMI cable. If the issue continues, reinstall or revert to the older version. It’s similar to audio problems seen in Spotify when switching devices.
            • Referenced by  laban48707 laban48707
