    PC Image- Problem with Share partition--> Doesn't cover all the SD card and not sizable
    Emulator Arcade/PC/Console
    image share partition doesnt cover card sizable
    • j2g2rp
      j2g2rp last edited by
      Hi community.
      Recently I tried to burn a microSD card to play recalbox on my PC. I follow the steps for burn a image for PC: Using Imager program from raspberry pi guys and using custom image for PC from recalbox page.
      The problem is that the card is a 128GB. It burns correctly but after the first boot when the partitons are generated the Share partition is only 19GB and left free space about 90Gb.
      I tried to resize the partition with gparted tbere are two problems with this:
      -First, after SHARE partition is OVERLAY partition so If I wan't to resize share I must move OVERLAY partition First.
      -Second: SHARE partiton is no sizable: After move the OVERLAY partition to the end of the microSD card I tried to resize SHARE with gparted but for some reason that partition is not sizable (buttons of size in gparted are locked for that partition and I can't do either with the graphic bar.
      Is a known bug or I'm missing something?
      There is something that I can do to solve this?
      Thanks in advance.
      100.7k
