    Recalbox 8.1 multi boot (PC) can't shutdown or reboot
    MediaCenter & Dualboot
    recalbox 8.1 multi boot cant
    • Jon10110
      Jon10110 last edited by Jon10110
      Good evening. I currently have a multi boot PC with Windows 11, Linux Mint and Recalbox and all is working except for the reboot/shutdown function. If I use reboot or shutdown within recalbox all it does is shutdown to a black screen with a _ in the upper left. The only way to fully shutdown or reboot is by using the PCs power button. Is there a way to configure recalbox to actually shutdown the PC or reboot to Grub? Thx in advance.
        Zing Global moderator Translator @Jon10110 last edited by
        @jon10110 We do not recommend dualbooting with Recalbox. We recommend installing Recalbox on a dedicated device, and we still recommend using one device exclusively for the system, and another device for storing ROMs/BIOS/etc.
        Considering this, we do not support this type of situation.
        But, there are some users who do dualboot, and there are even some tutorials here on the forum about it, I recommend you check it out:
        • https://forum.recalbox.com/topic/24642/tutorial-how-to-windows-recalbox-other-os-s-multiboot
        • https://forum.recalbox.com/topic/17464/dualboot-recalbox-windows-sur-pcs-laptops-avec-bios-ou-uefi-27-04-19?_=1660397671293
        Jon10110 1 Reply Last reply Reply Quote 0
        • Jon10110
          Jon10110 @Zing last edited by
          @zing Thank you for this information. I will look through those tutorials.
