    8.1 Issues on My Pi 4
    8.1
    2834
    • LP2112
      LP2112 last edited by
      Hey guys
      So I updated to 8.1 recently and it seems to have come with several issues on my Pi 4.
      The main one is that it isn't saving any of my settings after a restart. For example, I enter my Wi-Fi details and activate the Gameclip screensaver. Reboot and neither is saved so I have to do it all again each time to start my Pi.
      Second issue is that my shortcuts don't seem to be working. I use a PS4 pad and was always able to press Hotkey + Square to save, Hotkey + Triangle to Load, etc. Now, the only shortcut that seems to be working is Hotkey + Start to exit the game.
      Is anybody else having similar issues. I can't see anybody reporting them, which suggests it must be a problem on my end (hardware maybe?). I've already tried several SD cards and fresh installs but none of them solve the problems.
      Mazinga Zing 2 Replies Last reply Reply Quote 0
      • Mazinga
        Mazinga @LP2112 last edited by
        @lp2112
        Wait most of the community is french speakers only.
        I just made the Pi4 build. Try to save settings by going to the system menu and modify a small setting that will force save and reboot. Might be the 240p to 480i for instance.
        Even for a recalbox - software only without the recalbox dual SCART / VGA HAT it should push it to save display settings.
        Might be a way to save all your settings in one go.
        Also as with all pi, you can manually edit settings later on by mounting the SD card on a PC...
        LP2112 1 Reply Last reply Reply Quote 0
          Zing Global moderator Translator @LP2112 last edited by
          @lp2112
          This is a common symptom that you had a problem on the first boot, and that the system was unable to create the partitions correctly.
          Did you wait for the first boot until the end?
          What brand/model/size/class of your MicroSD card?
          We recommend using a Sandisk class 10 and 16gb MicroSD card for the system, and using an external storage device for personal files. A low class SD card will be very slow and can cause many problems, and a very large SD card tends to be problematic.
          • LP2112
            LP2112 @Zing last edited by
            @zing hey thanks for the reply. I was using a Sandisk 16gb Class 10. But I think it was having problems with data written to it.
            Bought a new one and the settings issue seems to be fixed. Still seem to have lost my hotkey shortcuts though. I've heard a factory reboot could help there but tried that to no results. May give it another crack to make sure though.
            • LP2112
              LP2112 @Mazinga last edited by
              @mazinga hey thanks for the reply. I sorted the settings issue by installing on a fresh SD. Think mine was a little long in the tooth.
              Still have the hotkey problem though so I may need to dig into the settings to fix that perhaps? Never done that before.
                @lp2112 After resetting to factory parameters, did you remap your joystick?
                • LP2112
                  @zing I did. Also tried mapping another button as the hotkey but that didn't work either. I've yet to try a different controller though. Using a PS4 pad at the moment so I'll try with something else when I get the chance.
                    @lp2112 One of the very unlikely possibilities is that you are using your PS4 joystick on a playstation 4 and on Recalbox, taking turns, and the joystick cannot fix the connection correctly, in which case, you would need to use your joystick in a dedicated way in Recalbox, and, reset the controller (there's a tiny button somewhere on the controller that can only be pressed with some thin, hard object, like a toothpick or the end of a paperclip), and remap it back into the Recalbox. As I said, it's unlikely, but it's a possibility.
                    The other possibility is that at some point previously you created a custom button configuration file, or a configuration overload file, and if that configuration is recognized as a priority, you would need to delete that configuration file, or modify it.
                    See these links:
                    • https://wiki.recalbox.com/en/tutorials/controllers/configuration-of-customized-buttons
                    • https://wiki.recalbox.com/en/advanced-usage/configuration-override
                    • https://wiki.recalbox.com/en/advanced-usage/configuration-override/retroarch-overrides
                    If not, try creating a custom configuration file, or a configuration overload file, and see if it works.
                    LP2112 2 Replies Last reply Reply Quote 0
                    • LP2112
                      @zing thank you for the detailed information. I'll give those links a proper look when I have a bit of spare time. Will look into that controller reset trick too seeing as I use the pad exclusively with recalbox. May get lucky with it.
                      • LP2112
                        @zing I finally got around to checking the links and trying the reset. I don't think the links will help as I definitely haven't created any custom controller configurations. Always used the standard. Sadly, the hard pad reset didn't work either. I'm at a loss! Tried another pad (generic USB) and hit the same issue.
