    Dreamcast problem no sound in reicast
    Emulator Arcade/PC/Console
    rpi3b+ reicast recalbox8.1
    • mix
      mix last edited by
      When i playing on dreamcast with reicast emulator i have no sound
      I don't want uses lr-flycast because is low performance on my Raspberry pi 3b+
      I'm using Recalbox 8.1-Electron
      Pier65 1 Reply Last reply Reply Quote 0
      • Pier65
        Pier65 @mix last edited by
        @mix hi
        This is a really problem. the recalbox team know the problem. And don’t have solutions. I have this problem too. 😓
          Scavy Global moderator @Pier65 last edited by
          @pier65 @mix
          Reicast is no more developped. Flycast is its successor.
          mix 1 Reply Last reply Reply Quote 0
          • mix
            mix @Scavy last edited by mix
            @scavy i dont want use a flycast because i have to overclock to get sometimes good emulation but i dont want to overclock
            Raspberry Pi 3B+
              Zing Global moderator Translator @mix last edited by
              @mix As Pier65 said, this has already been discussed, I recommend you read the discussion thread to understand better (it's in French, use google translator):
              https://forum.recalbox.com/topic/25894/problème-de-son-reicast
