    Recalbox RGB image jumps
    recalbox rgb jumps
    • Rei99
      Rei99 last edited by
      Hi everyone!
      I've bought a RGB Dual for my CRT, but image jumps also with 50hz jumper selected in the menu.
      It doesn't jump just with very old game ( Atari 2600).
      With 50hz jumper selected, also the menu will be at 50hz right? Why TV jumps?
      Thanks!
        Zing Global moderator Translator @Rei99 last edited by
        @rei99 I recommend that you check the information available at this link:
        https://www.recalbox.com/recalbox-rgb-dual/manual/
        And, if there are any unanswered questions, access our official discord, and join the channel dedicated to this subject (#recalbox-rgb-dual):
        https://discord.com/invite/NbQFbGM
        Rei99 nathonwade1 2 Replies Last reply Reply Quote 0
        • Rei99
          Rei99 @Zing last edited by
          @zing thanks, I've already check the manual on the site but there weren't info about.
          Try on Discord 👍
          • nathonwade1
            nathonwade1 Banned @Zing last edited by
            This post is deleted!
