    Composite on RB4 at new RecalBox8.1 - quest again))
    composite rb4 recalbox8.1 quest
    1643
    • IGA
      IGA last edited by IGA
      Why again never said or write that boot recalbox on rb4 via composite we need:
      Firs open recalbox\config.txt file, find the lines
      [pi4]
      arm_64bit=1
      temp_soft_limit=70
      dtoverlay=vc4-kms-v3d
      include crt/recalbox-crt-config.txt
      and change it to dtoverlay=vc4-fkms-v3d
      [pi4]
      arm_64bit=1
      temp_soft_limit=70
      Then we need go to recalbox\recalbox-user-config.txt
      And change sdtv_mode=2 - for NTSC
      or
      sdtv_mode=2 - for PAL
      after that, put the lines there:
      hdmi_force_hotplug=0
      hdmi_ignore_hotplug=1
      enable_tvout=1
      ..... and only after that we've got picture and sound on our TV
      • WHY IS SO HARD?????
        AND WHY THIS IS NOWHWERE WRITEN?????
      • Bkg2k
        Bkg2k Staff @IGA last edited by
        @iga Because it is NOT related to recalbox.
        It is related to raspberry's firmwares and they are evolving and changing on every release too. We CAN'T write documention of THEIR firmware just because Recalbox is relying on.
        IGA 1 Reply Last reply Reply Quote 0
        • IGA
          IGA last edited by
          @bkg2k Why not related?
          • IGA
            IGA @Bkg2k last edited by
            @bkg2k
            Recalbox is your firmware for their hardware. And file recalbox-user-config.txt, where listed only "uncomment for composite PAL" and no one else, is yours....
            I mean, maybe it would be appropriate to specify in more detail there all the relevant information on the case inside this file? (since raspberry is the first in the list in the download section)
            • Bkg2k
              @iga It's not our options. config.txt is a firmware configuration files that includes all other recalbox-*.txt. The include system is just a convenient way to split up all the firmware options.
              You can find updated documentation on raspberry website.
              We're doing lots of efforts to test all what we can, but of course we can't be accurate on everything, in particular on things relying on options Raspberry is changing all along the evolution of their firmware.
              • IGA
                @bkg2k said in Composite on RB4 at new RecalBox8.1 - quest again)):
                not quite understood - got raspberry nearly 2 years ago... Use only recalbox and retropie on separated micro sd. So what is options Rspberry is changed in this case?
