    Recalbox RGB Dual questions
    GamePad/GPIO/USB encoder
    recalbox rgb dual
    • Clanger
      Clanger last edited by Clanger
      Hi!
      What is the maximum resolution of the vga port? 640x480? 2048×1536? Will there be support for 75 or 100hz? I supose console games are limited to 60hz.
      Can I use a 100hz tv? If not... will there be support?
      Many thanks!
        Zing Global moderator Translator @Clanger last edited by
        @clanger I recommend that you check the information available at this link:
        https://www.recalbox.com/recalbox-rgb-dual/manual/
        And, if there are any unanswered questions, access our official discord, and join the channel dedicated to this subject (#recalbox-rgb-dual):
        https://discord.com/invite/NbQFbGM
        Clanger 1 Reply Last reply Reply Quote 0
        • Clanger
          Clanger @Zing last edited by
          @zing said in Recalbox RGB Dual questions:
          I've readed this manual, but it doesn't solve my questions. I want to use a crt monitor instead of a tv, but before buying the monitor and the recalbox rgb dual I would like to check that it works above 640x480.
