    Permanent loss of video signal version 8.1 Electron
    permanent loss signal version 8.1 electron
    1232
    • frenzy1995
      frenzy1995 last edited by
      After recording recalbox 8.1 Electron to a 64 gb sd card, a problem appeared: periodic loss of the video signal for several seconds (approximately every 10 seconds). The SD card is working (checked several times). Raspberry Type 3b+
        Zing Global moderator Translator @frenzy1995 last edited by
        @frenzy1995 Can you test a clean install, with the latest official version, on a 16gb class 10 microSD card?
        If that doesn't change the result, try another TV, then another HDMI cable, and see if there are any changes.
        • peyo
          peyo last edited by
          Same issue here.... RPi3B, SD 64GB. Occurs mostly on the emulationstation interface and with SNES emulation.
            Zing Global moderator Translator @peyo last edited by
            @peyo
            peyo 1 Reply Last reply Reply Quote 0
            • peyo
              peyo @Zing last edited by peyo
              @zing Tried with a clean install of 8.1.1 and had the same issues.
              But one thing that call my attention was I have some "under voltage" warnings (I have the NesPi case with a official power adapter from Rpi) that on previous releases were noticed when I turn off the system, but in this release I think the loss of signal maybe are correlated with this alerts.
              M__a__a__x 1 Reply Last reply Reply Quote 0
              • M__a__a__x
                M__a__a__x Global moderator @peyo last edited by
                @peyo
                I can confirm that a low power supply creates cuts in the video signal. I had the case with a Pi3 + superpicase. By changing the power supply the problem was solved.
                Recalboxment votre,
                M__a__a__x
